ActiveX with Fialab
I use activeX (LV7.0) with Fialab V5.0 for controling syringe pump and multiposition valve. While the program was running the warning "zero length" occured. How to deal with this problem?
(3,621 Views)
To shed light on this problem, when do you actually get this warning?  If you highlight execution on your LV program, we can then locate when this error occurs.  Is this error native to Fialab?
Nadim Rajabi
Applications Engineering
(3,607 Views)
Hi
Thank you for your help. This's picture for the time that warning occurred. I discussed with LV technician in Thailand and he suggested that this problem was caused by the Fialab program. In the past time (about 2 mounts ago) this program was work well but now it didn’t work anymore (I still use the same computer and same program).
(3,593 Views)
It seems to me, by the picture provided, that this warning is indeed a Fialab warning.  I am not too sure what the error message entails, but I would recommend to contact Fialab or search in the Fialab's help for documentation regarding the zero length error.
Nadim Rajabi
(3,575 Views)
