Addressing VXI-modules via GPIB-RS232-Adapter
i want to address the modules of my VXI-rack via a GPIB-RS232-Adapter (GPIB-232CV-A) and the E1406A-command-module, but dont know how to do that with SCPI-commands and havent really found examples in the internet on that topic. All examples that i find are using BASIC-programming or VISA-software, but i want to simply command the modules with the RS232-Adapter.
Can somebody give me an example on how the commands have to look to address a VXI-module?
Echo
(4,047 Views)
Hi echo,
I am not sure if this will really hep you, but I found this document where some explainations fit to your question:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2YDCAY&l=en-US
Have a look at it,
Ramona
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,949 Views)
thanks for the link. I couldnt really get it to work like in the link, because my Resmon looks different when i boot the system and i dont get the GPIB-VXI> line prompt.
But i just made it work, by using the commands mentioned in my command module E1604A and using RS232:
vxi:send 24,"meas:volt:dc?" //24 is the logical address of my voltmeter
vxi:rec? 24
Maybe this will help somebody with similar problems.
Greetings,
Echo
(3,943 Views)
