Again closing references and reentrant vi-calls
i create a static-vi-reference that is then opened in a loop for 10 times in parallel. At the end i wait for all are finished. Then i close the reference that was created from "Open Vi reference".
Question 1: Do i also have to close the reference that is coming from "Static vi reference"?
(This 10x opening happens each second).
Question 2:
Currently the vi that is used as static vi-reference is set in VI-Poperties + Execution to "Shared clone reentrant execution".
What about all the subvis that are called in there? Do i also have to set them  to "Shared clone reentrant execution" or is this done automatically?
Question 3:
I have the effect that everything seems to run fine but the CPU and memory increases
After starting the program 50 MB RAM and CPU at 15%
Then i can be seen that there are cpu-peaks from time to time, Seems as this are the parallel-calls.
Then cpu goes higher and higher up to 72% and ram goes to 230MB (after 4 hours)
Is ther something that can be changed in this mimic? There is nothing else running that can eat my cpu und ram.
Thx
(4,378 Views)
(4,375 Views)
