Agesa Again
I have read there are several problems with the Agesa driver, but I have found no answer to the timeout problem when trying to comunicate with a E4403B using Agesa LV_80 driver. Im using the A.07.6 firmware of the E4403B, because I don't have the memory expansion right now. Is there any way to make them work without upgrading the system? And, upgrading the system will be the answer? Im using LV 8.0
Thanks!
Enrique Preza Hdz.
(3,665 Views)
Hello Enrique,
       When I did a search for "E4403B timeout" at ni.com's upper right search field, I found this KB, which should help you out.
Cheers,
NathanT
(3,646 Views)
We can help you get the agesa IVI driver working, but I also wanted to let you know that there is now a LabVIEW Plug and Play driver for the Agilent ESA and PSA series:
This driver has LabVIEW source code available.
(3,643 Views)
