Agilent 1100 syntax error
Or unheck the option 'use localized decmal point' in LabVIEW
greetings from the Netherlands
Message 11 of 28
(3,404 Views)
Thank you both very much for your replies!  Unfortunately, I'm still getting the error.  Below are my current regional settings.  I also tried unchecking the "ignore local decimal" setting in LabView options (and restarting LabView), but I'm still getting the error.
If it helps, here is the error I'm getting from the "Configure Pump" VI in LabView:
Once again, thanks in advance for your help!
Message 12 of 28
(3,387 Views)
That is not at all the same error as this thread discusses. What sort of connection do you have to the instrument? Can you communicate in MAX?
Message 13 of 28
(3,379 Views)
It seems to be the same error that was fixed by changing the decimals where the timeout is coming from the Configure Pump VI.  All the other included VI's with this driver work just fine.  I can initialize and turn on the pump, but I just can't configure it.
Message 14 of 28
(3,369 Views)
Two completely different error codes and messages. How do you figure that it's the same error?
Message 15 of 28
(3,360 Views)
If I change the regional settings back to commas, it will give me the other error code.  Would that be more helpful?
Message 16 of 28
(3,344 Views)
It means you fixed the first problem and now have a second.
Message 17 of 28
(3,330 Views)
I would love to talk with someone that has gotten these pumps to work on labview. I am looking to purchase a few 1100 series pumps but would like to get some questions answered first.
Message 18 of 28
(3,279 Views)
have you looked through http://kau.diva-portal.org/smash/get/diva2:576273/FULLTEXT01.pdf here they constructed an HPLC with the ag1100 driver.
They shared their developments, but the links they provided are unfortunately not available anymore. I will therefore share them here.
password is: OnlineHPLCexjobb
when you acquire the pumps, i will suggest that you opt for the permanent ip configuration, then you do not need the "bootstrap" that is described in the driver documentation.
otherwise it should be rather straight forward.
Kind regards
Message 19 of 28
(3,264 Views)
Hi there!
I got them to work, it is my paper and my files that are linked by Rolri just above this message. Unfortunately it was a couple of years ago so I don't really remember all details but I will try my best to answer any questions you may have. The paper itself might not be of much use to you since it is motsly focused on other stuff than LabView programming, but download the files and try to make some sense of them. They are quite messy and there are probably much better ways of doing things, but they did the job for me 🙂
Rolri: Thanks for uploading the files here since my original hosting seems to have died 🙂
Message 20 of 28
(3,252 Views)
