Agilent 2702a control
I would like to control the Agilent 2702A  using LabVIEW but I was not successful in doing so. I have attached the simple diagram I was trying to use. I would appreciate any comment helping to run the oscilloscope. I have used Visa write with the recommended commend list by the Agilent (SRATe? & DATA?). I even tried to use the Sequence function with the Keysight Command Expert but I was not able to find the command set for this instrument.
(1,317 Views)
You are initially requesting the information stored within the instrument's ROM and the instrument responds properly; however, it you have not run the instrument, then there will not be any waveform DATA to extract regardless of channel.
Look here for the manual.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(1,273 Views)
