Agilent 33220 ethernet examples
Newby to LabVIEW programming.  Setting up an Agilent 33220A with LV8.6 Base, using ethernet communication.  Eventually, I will have 4 Agilents attached to this system.  Using static IP assigned to the Agilent:  192.168.1.11   Connected to a secondary ethernet adaptor assigned 192.168.1.10 for the private network.  MAX finds the Agilent as a Remote System, but returns a VISA error OxBFFF00A7 (VI_ERROR_MACHINE_NAVAIL) in Devices and Interfaces, and displays p&p NI-VISA as Software.  I have downloaded the driver ag33xxx (plug and play, not project related), but no examples show up for ag33xxx.  MAX shows NI-VISA 4.4.1 as installed software with NIVisaServer.exe and NAvisaic.exe.
Control of the Agilents will simply be start/stop using on-screen pushbutton and changing operating parameters such as frequency and duty cycle.
(3,591 Views)
Using the Remote Systems is simply not correct.
Right click on Devices and Interfaces and select Create New>TCP/IP Resource. Follow the directions from there. There are some differences depending on the type of network instrument you have.
(3,580 Views)
