Agilent 34970A how to measure current and temperature simultaneously via 34901A
Fine but what is the actual scan list?
Message 11 of 21
(3,318 Views)
for temperature 101 and for the current 121
Egemen
Message 12 of 21
(3,314 Views)
Okay, that seems fine and by looking at your code, it looks like you did the modification correctly. At the moment, I only have access to a 34980 and not the 34970 so I cannot run the code. What you might do is set some breakpoints and step through the code to see when the instrument is throwing the error. Also try setting one and then the other channel list to be empty so that only one function is called.
Can you run any of the other examples? The EZ Scan allows you to select a current measurement. It does it slightly differently so it would be interesting to know if that works.
Message 13 of 21
(3,307 Views)
Thanks your support. I am in the same situation too here. I am out of office and I have no chance to access to my 34970A till friday due to my personal stuff. I run other examples. They works well and also I made basic temperature and pressure measurement programs that I need. I attached them below. They works pretty well. But I cannot combine these two programs into one program.
Egemen
Message 14 of 21
(3,304 Views)
Hi Egemen,
I only see this discussion yesterday evening and  you have probably resolved this issue, but I made some modification to your code. If you can give it a look and tell me if it is usefull for you.
Bye,
Lamberto
Message 15 of 21
(3,131 Views)
Hi Lamberto,
Thank you for your interest. But I cannot open the VI, because I have labview 2009. Could you send it available for it for me?
I solved the problem a long time ago, but I forget to mark as solved. I want to see your modifications on the vi too.
Egemen
Message 16 of 21
(3,129 Views)
Hi Egemen,
I'm sorry, but I'm not aible to do that, but you can see in the attached files your block diagram and my modifications that consists only to put in serie the blocks you have put in parallel.
Lamberto
Message 17 of 21
(3,107 Views)
Thank you Lando67. I get it. 😄
Egemen
Message 18 of 21
(3,102 Views)
Hi every one,
I am using Labview to control Agilent 3210 and I got an error like this : Error -1073807346 occurred at VISA Open in ag33xxx - Initialize.vi->ag33xxx - Arb - Application.vi . Would you like to help me to figure out the reason why I got it? Agilent 3210 and PC are connected by USB.
Thank you very much.
Message 19 of 21
(3,073 Views)
@stranger1 wrote:
Hi every one,
I do not know that error but searching on the net and come across this one. Maybe it will help you.
http://www.ni.com/support/labview/visa/verr3.htm
Egemen
Message 20 of 21
(3,070 Views)
