Agilent 34972 EZ examples freeze DAQ
I'm playing with Labview and the Agilent 34972 to get a feel for instrument control.  I am using two of the example EZ blocks from the pallette, pictured below.  My simple vi runs fine using just one EZ, either one.  However trying both together freezes the daq.  I think I am initializing incorrectly...?  Any help is appreciated.
(3,187 Views)
Found the answer here: I should have had the measurements in series.  Should I delete this thread moderators?
(3,180 Views)
Hello t3mpn3ff,
Glad you found your answer. You can delete this thread if you want since no new information was discussed, or feel free to leave it open. I will leave the link to the other forum below just for clarity.
Agilent 34970A how to measure current and temperature simultaneously via 34901A
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Agilent-34970A-how-to-measure-current-and-te...
Thanks!
Erika
Technical Support Engineer
(3,131 Views)
