Agilent 8164A measurement system with lambda scan power value allways be change to uW
Hi
When i use the hp816x with the lambda scan,i have some problem,why are the power meter's unit allways be change,
that allways when program to execute lambda scan.vi the powermeter will be change to uW,how can i setting this problem?
thx!
(4,482 Views)
Hi there,
The Instrument Drivers you downloaded from the instrument driver network in ni.com are mostly provided by the thrid-party companies and thus are not supported by national instruments
(Because the low-level dll inside the VIs are developed by the driver provider)
For a more detail way of using those instrument drivers, the simplest way would be asking the instrument vendors for help
(4,453 Views)
