Agilent 816x Driver for LAN Interface?
Hi Folks,
Dose anyone have a decent LabVIEW driver for the Agilent 8163B or 8164B?  The newer versions of these instruments have a LAN interface that I'd like to use:
http://cp.literature.agilent.com/litweb/pdf/5989-9352EN.pdf
The document describes how you must append a "new line" to each command or query.  The old DLL and wrapper driver doesn't support this.
I've got a 81571A VOA module installed, so the list of commands I'd need is relatively small.  Before I set off to write my own driver functions, does anyone have one they'd be willing to share.
Scott
(4,098 Views)
Hello Scottndsky,
A driver makes VISA calls to the device. Since we do not have a driver avalialbe on ni.com/idnet, I would recommend trying to adapt one of the drivers we already have online. Hopefully this will get you started with writing your own driver.
Maggie
ni.com/support
(4,069 Views)
