Agilent 82350B PCI GPIB Card
Hi
I'm using Labview & O.S win 98
It might be a problem to work with this card ?
And if there any, what the solution ?
Thanks in advance.
(4,777 Views)
Hi Valda,
I have heard of customers using Agilent GPIB cards with LabVIEW. I can only assume that it will work just fine.
Best Regards,
Aaron K.
Application Engineer
(4,777 Views)
Hi
I tried to work by VISA lib or 488 lib
but It wos not successful.(No connection at all).
The NI Daq. not recognaze the card.
Can you give me more tips or example.
Regards
(4,777 Views)
Hi Varda,
I believe you have to enable tulip in the configuration for VISA. 488 will never work with that card. For more nfo no VISA refer to http://pong.ni.com/public.nsf/websearch/3B3626D9C1F999218625694200791AD7?OpenDocument
Aaron K.
(4,777 Views)
I have the same problem to use MAX with Agilent 82350B card. The doc supplied leads nowhere.
(4,777 Views)
