Agilent 86100A drivers for LV2009
I am having some trouble getting LV2009 to control my Agilent 86100A scope.  I found drivers at:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E93A5659CE034080020E748...
I connected the scope with GPIB and am able to see it in MAX.  I installed the driver above and found a .llb file (that I had converted from LV5.x to LV8.x so that I could open them).  When I try to open the .llb file it brings up an LLB Manager.  Then when I select a vi it searches for a ag86100a.dll file and does not find it.  It then gives a warning (see attachment).  Some of the vi's seem to work, but it feels like something is wrong.  How can I get rid of the warnings and how can I get the vi's to show up under the instrument driver functions?
(3,975 Views)
I don't think that's a big problem: it looks like the calling VI expects to find the DLL on windows/system folder, but it finds it on the same folder as itself, so it gives a warning. If you don't want to see the warning, just try to copy the DLL onwindows/system folder.
(3,949 Views)
Yep, this just looks like a dependency warning, indicating that the DLL is in a different location than the calling VI expects (as xdaf said). This shouldn't cause any issues.
Justin E
National Instruments R&D
(3,928 Views)
And if you want to have the VIs show up on your palette, install the LabVIEW driver in the instr.lib folder.
(3,914 Views)
