Agilent DSO5054A waveform read problem
I'm using the Agilent DSO5054A with GPIB connection.
I tried to get a driver but there are two ...
DSO5054A Drivers
Which one should i use?
I already have installed the IVI driver but there is the problem that the signal on the oscilloscope starts at 0 V and ends at 2.5 V on the y-axis but in my LabView programm it starts at 700 mV and ends at about 1350 mV...
(3,510 Views)
Hi WEni,
depending on what LabVIEW Version you have, I would go for the following link:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=1E5E6D70FCA569A3E0440003BA7CCD...
You copy the content to:
C:\Program Files (x86)\National Instruments\LabVIEW 2016\instr.lib
and run the examples.
When I open the Agilent 6000 Series Acquire Continuous Waveform.vi, the autoscale for the Y-axis is enabled. Is that the case for you as well?
Best, Niko
Niko NR
Systems Engineer, National Instruments
(3,484 Views)
First of all thanks for the fast answer 🙂
I followed your description above but there is still the same problem.
I add my currently used programm build based on the data transfer between the oscilloscope and the computer down below.
I implemented a function where i can scale the x- and y-axis by myselfe so i disabled autoscale.
It seems that the computer doesn't get the right measurement values from the oscilloscope.
I also add pics of what i should get from the oscilloscope (red marked in the pictures) and what i really get.
 All four pics are in a pdf because of their big size.
What for is the "Configure Continuous Acquisition" vi?
Best, WEni
(3,477 Views)
