Agilent E2050A lan-GPIB gateway and Labview 6
I am using a system that has a E2050A in it. All the HP/Agilent lowlevel drivers are installed (SICL/VISA etc). Under Labwindows CVI everything works fine, but I need to run some Labview code, but in Labview I can't see/talk to ANY VISA resources, not even the serial ports! Has anyone managed to configure a system with this configuration successfully?
(4,759 Views)
Here's a knowledge-base about using HPIB cards in LabVIEW:
http://www.ni.com/cgi-bin/search/search.cgi?scope=knowledgebase&query=20KCIS7Z
Be sure to follow everything carefully. If this doesn't help, you can search for more knowledge-bases at http://search.ni.com/search/?layout=KB
Randy Solomonson
(4,759 Views)
Unfortunately, my question isn't about an HPIB card, it is about a HPIB-lan gateway, similar to the GPIB-ENET box that NI do.
The problem with installing HP SICL and then NI-VISA and NI488.2 is that the 'standard' NI488.2 doesn't support a 'VISA LAN client' type remote interface.
The NI GPIB-ENET box comes with NI488.2M which seems to support what I need, but unfortunately it is not available for free!!
What really puzzles me is why Labwindows CVI works, but LABview doesn't, what is the difference with the VISA access functions?
Paul
(4,758 Views)
Paul:
There is a known problem with the Agilent VISA driver version J, specifically with the way it is called by LabVIEW. They have a patch for it available.
Dan Mondrik
Senior Software Engineer, NI-VISA
(4,759 Views)
Thanks....I'll follow this lead up, and let everyone know if it resolves the issue.
Watch this space!!
(4,759 Views)
Dan,
Can you give me any pointers to where I might find the patch. I've searched Agilent's support site and looked throough their IO drivers download area....could find no mention of a patch to resolve any Labview interworking issues.
(4,759 Views)
