Agilent n3300A constant voltage operation
Hi, I have been trying to use the following progam to fix the voltage output of Agilent n3300A and readout the current measurements. However the intrument is reading out the open circuit curent/ voltage values of the load  and does not regulate the voltage to the desired value. Is there anythng wrong with using the voltage configurartion driver to set the voltage or is there a better way to write a voltage to the instrument.
(3,643 Views)
Hi Aru1,
I found this forum in which this is discussed, I believe you could post your question in here, since they are experienced users with the Agilent driver, they might know what seems to be amiss. You could also try communication using NI-VISA to write and read values from the device. In the LabVIEW examples, you can find some basic examples to establish this communication.
Best Regards,
(3,612 Views)
