Agilent u1731a data acquisition
Hi
I would like the Agilent u1731a LCRmeter with Labview.
This LCRmeter can plug into an USB port. I would like develop a VI to read the data measured. The default values for baud rate, parity, data bit, and stop bit in the LCR Meter are 9600, n, 6, and 1 respectively.
Can I use Labview to read the measurement from this device ?
Can I use the VISA functions ?
Thank you
Yannick
(3,336 Views)
via USB this device looks to behave a a serial port connected instrument.
So yes you can use that in labview with VISA
greetings from the Netherlands
(3,327 Views)
Actually, you should have checked with Agilent. Without a published set of commands, you would need a serial port sniffer such as portmon.
(3,315 Views)
