Any Labview VI/driver support for Advantest U4341 RF Field Analyzer control via GPIB-USB-A
Using LabVIEW 6.1 to develop an instrument application with the Spectrum Analyzer
(3,608 Views)
Using MAX, the error message received is:
iberr = EABO
I can communicate with the GPIB device (U4341) Address at 30 but cannot read/write data to the U4341.
I guess the U4341 is rather old but how do I get the correct GPIB instructions or settings
(3,608 Views)
There is a website that lists common GPIB error codes and solutions (EABO...). If you go to ni.com >> Technical Support >> GPIB (option 2) >> (option 3) "GPIB Error Codes and Common Solutions" you will get it.
You could find a driver for this instrument at http://www.ni.com/devzone/idnet/default.htm . If it's not listed there, it leaves you with one of a couple options. First, I would like you to submit a request for this driver at: http://zone.ni.com/idnet97.nsf/instrumentdriverrequest/
We develop drivers based on demand and popularity so the more requests we have for it, the greater the possibility that we will develop one.
If you would like to try developing your own instrument driver (or modify the existing one), we have documentation, model instrume
nt drivers, and driver templates to help at :
http://www.ni.com/devzone/idnet/development.htm
We also have a syndicate of third party vendors that specialize in National Instruments' products and services. Some of the vendors specialize in driver development. I would suggest contacting one of the Alliance members at:
http://www.ni.com/alliance
There are example VI's in LV on Instrument Connectivity. If you go to the Help menu >> Find Examples.. >> Hardware I/O, you will see a couple and Examples.. >> Fundamentals for File and String manipulation. I would suggest tweaking them to suit your application. Also the specific command that your instrument responds to can be found from it's manual.
Some useful resources for your application are
ni.com > NI Developer Zone > Development Library > Instrument Connectivity
http://search.ni.com/?col=alldocs&layout=TechResources&ql=a , to search examples and knowledge bases
http://www.ni.com/support/
Hope this helps.
(3,608 Views)
