Anyone has an instrument driver for Agilent E8364 50GHz PNA
Does anyone have a working instrument driver for the E8364 50GHz PNA? I am currently tryin to use the agpna instrument driver downloaded from NI but i am having errors. The PNA balks that the "query is unterminated" and then the VI times out. Please let me know if you have a working instrument driver.
(3,511 Views)
Is this the driver you are downloading?
If so,
- Are you running the Getting Started VI to test communication?
- Did the ID query pass?
- Make sure you have VISA 2.6 or later installed.
- Try running NI-spy with with the Log to File option enabled and post the spy capture.
(3,511 Views)
