Anyone know how to communicate with Manta MTS-5000 test set ?
Hello.
Does Anyone know how to communicate with Manta MTS-5000 test set ?
I try to establish a TCP/IP connection with LabVIEW software and a MTS-5000 test set.
I have to send ASCII command in an Transmit and receive form. And would like to store infos in an Array.
Waiting for your help !
Thx. Phil
(3,477 Views)
Follow section 5.3 of the Users Manual in order to establish an Ethernet connection to the MTS-5000 hardware.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,422 Views)
Thx for you reply. This i already know 🙂
I'm looking for a LabVIEW code to establish the communication with the MTS-5000.
For example: I would like to pass that command and catch back the answer:
GET .general.productCode
Answer: MTS-5000
You get the point ?
I have catch with Wireshark the IP tracing and it seems to transmit to the PC thru port 80 but in LabVIEW i get and error with the error cluster.
Phil
(3,417 Views)
Ethernet comms uses port 60000---built-in web-server is on 80.
(3,405 Views)
Hello.  Could you send me a labview code to communicate a command to the Manta MTS-5000 ?
(3,400 Views)
