I am using LV 6.1 with Windows 2000 and trying to communicate serially with Tenma power supply, ThermoOrion pH meter and kdScientific syringe pumps via RS-232 cable. I've done the hardware test to ensure the serial cables are working and the computer can send and receive signals. However, when I use "Serial Communication.vi" to talk with each instrument, there is little evidence that anything is happening:
Tenma power supply--goes into "REM"ote mode, showing it recognizes something from computer, but then only makes 3 or 4 beeps when writing a command to the power supply
ThermoOrion pH meter--no evidence that commands from computer even get to met
er
kdScientific syringe pumps--will go into "REMOTE" mode and every once in a while will provide some feedback to the computer, as if it's trying to respond, but response is gibberish and commands from computer have no effect on operation
If there is further information I can provide that might help, please let me know.
Adios
