App failed. Error code 30253002. Unable to allocate Memory.
I developed an application. In that i am using two serial ports to  read different data. i am running loop with 300ms delay. what could be the possible chance of error.
(5,241 Views)
That is not an error code generated by any NI hardware or software. I think you have the wrong forum.
(5,222 Views)
Error code is changing rondomly. this time i got 30115002.
(5,215 Views)
Still an unknown error. So far, you have provided no information other than some cryptic numbers. What language you are using, what NI hardware, what NI software, are all mysteries.
(5,211 Views)
Well, I am using Labview 2012, touch panel project. Touch panel has WIN CE operationg system. Hardware  is Frienndly arm board(mini2440).
(5,198 Views)
(5,197 Views)
