Arduino Error 5003
I am trying to connect my arduino uno to labview and am getting error 5003 "A timeout occurred while trying to read from the arduino". I verified that the 'blink' example program in the Arduino software works and so the arduino is able to connect to my computer. I am attaching my program below where I also tried to increase the timeout time to 100ms. I am not sure if the send receive vi is hooked up correctly, but everything else is exactly as I have seen it in numerous other examples on the web. I do knot know where the problem could be .
Thanks for your help,
Dan
(2,793 Views)
Hi
Which vi's are you using to commnicate. (init etc)
And which program in the arduino, if possible upload all.
greetings from the Netherlands
(2,781 Views)
