Are Eltima Virtual Serial Ports visible in Measurement&Automation and usable ?
I need to test a driver developped with LabView for a hardware that I don't have => I plan to develop a test software and to use paired virtual serial ports (created with Eltima Virtual Serial Ports Driver), but I wanted to know first if this works and if these virtual ports will be visible in M&A and writable/readable in LabView.
Thank you.
(1,995 Views)
Accepted by topic author snpro
Theoretically, it should work as long as Windows can detect it as a COM port, NI MAX will populate it as Serial port in the VISA control dropdown.
Santhosh
Soliton Technologies
(1,940 Views)
Thank you 😊
(1,889 Views)
