Are there any VI's for a Keithley 705 with a 7052 matrix card?
The Keithley 705(GPIB) VI at ni.com is not set up for matrix card operation. Does anyone have a VI for this, usable in Windows NT?
Message 1 of 9
(4,173 Views)
I am interest in your request. Actually, i don't answer for you, but I also facing the same problem. My keithley 705 didn't have the matrix function. so i can't do my experiment. If you have any idea, at all, could you be so kind to send me the answer?
Thanks.
Message 2 of 9
(4,173 Views)
I wrote two vi's to control the 7052 card. I did not post it here since I didn't do a thorough development of the VI, just what I needed to get the job done. I've attached them here. The 705 must be in the matrix mode before running these. 7052-1.vi can be used when connecting each row to one column, the input is a 1x5 array. The value of each element is the row # that column is connected to. 7052-2.vi is more general. The input is a 4x5 array of 0's and 1's, for open and close.
Message 3 of 9
(4,173 Views)
Referring to your Vi here, is there any possibility that you may get the ke7065.Vi?
I need that for my project. Is there any other way that I can contact you?
I do need your help. Thanks.
from
saw chii jian
Message 4 of 9
(4,173 Views)
from
saw chii jian
Message 5 of 9
(4,173 Views)
The VI's I sent for the 7052 should work for the 7065 as well if it is in a 705 scanner, although I've never tried it. We are using our 7052 for Hall measurements. We are only testing low resistivity samples so we saved some money by getting the 7052 instead of the 7056. If you would like to discuss further call me at 603-885-9106.
Dan Reese
Message 6 of 9
(4,173 Views)
Thank you for your reply. But I face some problem open your 7052.vi with my lv6.0.
is there any way that you may open your VI here and save it with lv6.0 for me? Will it affect the functions of the VI?
thanks.
Message 7 of 9
(4,173 Views)
Try these.
Message 8 of 9
(4,173 Views)
Thank you.
Message 9 of 9
(4,173 Views)
