Are there any good tutorials on how to create a VISA driver for an Ethernet device?
I have a custom device that is built by our company and I would like to see if  I can control it through LabView to
help automate the testing portion of this device.
The device has an Ethernet port and a USB port and I would like to control both as there are defined commands
for this device but  I am not sure where to begin.
Any advice is appreciated
thanks
(3,376 Views)
There are the guidelines at http://www.ni.com/downloads/instrument-drivers/.
They are most useful if the instrument's firmware was designed to be compatible in the first place. Is it a USBTMC, or VXI-11, or LXI? Does it use standard SCPI?
(3,368 Views)
Take a real LabVIEW PnP instrument driver for example and read the below document should be enough for a quick start.
http://www.ni.com/white-paper/3271/en
Charles
(3,362 Views)
Thanks for the links...
I have some reading to do...
(3,359 Views)
