Assigning Static USB-Serial COM Ports
I have an application where I am using a few stepper motor drivers that will have an RS-485 to USB adapter, which will be used to commuicate via VISA and LabVIEW. The problem I am having is that my computer is auto allocating the COM port differently each time I plug in my device and I was curious as to whether or not there is a way to assign a COM port/USB port as static so it does not change when I plug in a device to a certain designated port. Is there a way to do this in Windows settings or a way to search for the USB connection and write to its port whenever it changes?
(5,404 Views)
In general, the vendor of this kind of USB device will not confit the "serial number" to the rs485-USB cable. But, you may find the chip vendor's website for the tool of program the "serial number" to this chip. After that, your chip will for a unique serial number. Then you can find by searching the Windows regestery by USB pid vid and serial number to find where it is.
(5,381 Views)
To avoid this problem I use FTDI devices. You can name these devices and search for the name. The FTDI driver reports the used COM port number.
This is how I use USB serial ports in my applications that are used by many users (and computers)
Maybe you can do the same with devices from other manufacturers.
Kees
(5,377 Views)
