Audio Precision bus (APIB) with LabVIEW?
I'm trying to control an Audio Precision SYS-2722 with LabVIEW, but it doesn't have any GPIB port, only APIB and an APIB-USB adapter.
Do you know if there are a way to do this?
NI-VISA see the device as an "USB Raw" device and not an USB instrument.
Thanks!
(7,020 Views)
Dear SylvainV,
I found a APx LabVIEW Driver on the Homepage of the Vendor Audio Precision.
And on the buttom of this PDF here APx Automation with LabVIEW you can find a compatible list of aby AP-Devices and the compatibility with LabVIEW:
And here is also the Download Link: APx LabVIEW Driver v4.1.2
NOTE: This Driver is not supported by National Instruments so for any Questins to this Driver and its API please contact the Audio Precision Support!
Kind Regards,
SG3 | Applications Engineering | National Instruments | NIG |
(6,924 Views)
Thank you for your answer. Sadly, my 2722 is the A version, not the G version so it looks like it's not compatible with LabVIEW.
(6,917 Views)
Dear SylvainV,
Thats true but I think you could use the ActiveX automation in LabVIEW to.
Here how to use AcviceX in LabVIEW.
Using ActiveX with LabVIEW
Kind Regards,
(6,913 Views)
