Automating Measurement Automation Explorer
I'm trying to automate the installation of NI software and scope card
installation. After the NI scope software and scope card is installed
it seems that a refresh is required in NIMAX. Is there a way to
automatically cause a device refresh from the command line or another
program? I'm using Measurement & Automation Explorer 2.2.0.3010.
Message 1 of 8
(6,098 Views)
Hello Tom,
Thank you for contacting National Instruments.
I am attaching a folder which includes a VI to programmatically
refresh MAX from LabVIEW.
Keep in mind, if your MAX window is not titled "Measurement &
Automation Explorer" you will have to change a few string constants to
your actual MAX window title.
I hope this helps,
Sean C.
Message 2 of 8
(6,096 Views)
Sean,
Thank you. The zip file was empty. Can you repost it?
Tom
Message 3 of 8
(6,096 Views)
Tom,
I apologize... Here is the folder with its contents.
Sean C.
Applicaitions Engineer
Message 4 of 8
(6,096 Views)
Is there a way to do this without Labview? I use VB to control my hardware and would like to have it refresh and remove unused hardware automatically
Chris
Message 5 of 8
(5,904 Views)
Hi Chris,
What exact hardware are you using?
Chris R.
Message 6 of 8
(5,839 Views)
We use mostly PCI 4472's as well as USB9233's for acquistion and various cards for outputs. In particular I need the systems to automatically remove the entries and reset the device numbers when equipment is changed.
Thank You
Chris
Message 7 of 8
(5,837 Views)
Hello Chris,
While there is no similar application that has been written for Visual Basic, I would propose an alternate solution.  Instead of trying to keep the Device names the same regardless of adding/removing hardware, scan for the current names (whatever they are) and use those in your application.
I hope this helps!
Message 8 of 8
(5,805 Views)
