Avionics interface controller baud rate setting
Hi All I am trying to use  condor engineering's  AIC (Avionics Interface controller card)  for  recieving serial  data (RS422, asyncronus, diffrential data,even parity,7.8125 KHZ)  but the problem is that iam not able to configure the  card to set baud rate of 7.8125 K  because its giving option to select only some of the predifined baud rates.
So please help me, how i can set the baud rate of 7.8125 K  bps.
(3,851 Views)
If you're referring to setting the baud rate on the card, then I don't see how we can help you - you should contact the manufacturer of the card.
Or, are you talking about setting the baud rate for the serial port on the computer, or for whatever serial port interface that you are using? In this case you need to specify what you have (i.e., whether you're using the serial port on a computer or a device like a USB <--> Serial converter box) and what operating system, since there are some limitations on setting custom baud rates.
(3,844 Views)
Thanks for u r  response.
At  present  iam not using serial port of computer.However after  u r  reply, I am thinking of using serial port of computer.
please suggest me how can i use coustomised baud rate for serial port.
OS- windows XP
(3,821 Views)
If the hardware does not support it, you will not be able to set a non-standard baud rate. You have to get a card that allows for custom baud rates such as this.
(3,813 Views)
