BAD CRC ddb0ec04 (should be 0c81c709) with extracting merged.idb
Dowloaded several times the NI488224.exe and are always confronted with the following error message :
BAD CRC ddb0ec04 (should be 0c81c709) with extracting merged.idb.
log of winzip shows the following :
Extracting merged.idb
bad CRC ddb0ec04 (should be 0c81c709)
Warning: the size of the extracted file (16480469) does not match the uncompressed size (16480256) recorded in the zip file
If I continue with extracting the other files I also get a similar error with a couple of other files.
OS: Win XP SP1
Thanks for your help.
(3,745 Views)
Hi, I've just downloaded the 2.4 version of the GPIB driver myself and the zip file got extracted without any problems and launches the executable. So, there is nothing wrong with the zip file itself. There haven't been any reports about this either. I've used WinRAR 3.42. Maybe there is something wrong with WinZip itself but my guess is that there was an interruption during the download process or your firewall blocked some files during the download. I would check those two things first because I'm pretty sure the problem is not coming from our FTP server. Regards. JorisV
Message Edited by JorisV on 09-28-2005 07:38 AM
(3,734 Views)
