BFFC09F9 -1074001415
Receive this error when attempting to write to IFR Signal Generator
through USB/GPIB converter.
Normally works OK but occasionally - in 24 hour test - gets this
error.
Have been unable to locate the error anywhere - not in vpptype.h.
What is causing this error? What can i do to aviod it?
(3,161 Views)
Is there any text associated with this error? Have you noticed a pattern of recurrance for this error? I'll try to do some research on this. Could you provide some more details? Thanks!
Craig H.
(3,161 Views)
