BK Precision 85XX Run Constant Current Mode Operation.vi"
I am trying to interface BK Precision 8500 Electronic Load with LabVIEW. I need the .vi file so that I can get access to the .vi block diagram of the same. I am using it in Constant current mode. Basically I want to change the load of my DC -DC converter by changing the current. Could someone please help me get access to this .vi block diagram? I have a Student version labVIEW in my system. I don't know if that is the reason I am not able to view the block diagram when I got this .vi link in NI Example Finder.
The link for the .vi block diagram:
(4,221 Views)
How did you gain access to this VI? Did you use LabVIEW to search for the BK drivers and access it that way? If not, I can help you navigate to the drivers and examples. Also, when you have access to the example, is the front panel just gray or does it have a gray grid? If it is gray with no grid, it may be locked and you won't be able to access the block diagram. If it has a grid, you should be able to press "Ctrl" "E" and view the block diagram. A student version of LV should not prevent you from accessing the block diagram, that is if it is available for viewing in the first place.
Jordan
(4,203 Views)
I downloaded the driver and was unable to open the VI itself from the example finder. Error message about the path
(4,200 Views)
Can you try the examples again?  I just tried and they seem okay. You should be able to view the block diagrams.
(4,187 Views)
Using 2010, there is no problem when I browse to the VIs and open the project. From the example finder though, I get the message:
"That file could not be found or opened. You may need to reinstall your examples."
Then it gives the path to the example. I installed the driver by going to the Tools menu and Instrumentation>Find Instrument Drivers. I just now deleted the driver and did a manual download. After restarting LabVIEW, the example finder now works. I can't explain why but it all seems okay now.
I think the op meant VI and not block diagram.
(4,185 Views)
 Hello lamtesting
Have you made any progress on this issue from the comments made by the previous posters?  I would like to be of assistance to you on this issue and it would be great if you could give me a status update.
Thank you very much!
Sincerely,
Greg S.
Sincerely,
Greg S.
(4,169 Views)
