BOP 36-12M / BIT 488-B
I'm working with a Kepco Power Supply (BOP 36-12M) and a Communication card (BIT 488-B) and trying to control from Lab View.  My problem is that I can't add and configure an interface for my GPIB card (Advantech PCI 1670 GPI Card) under MAX. I have updated de NI 488.2 and VISA drivers to latest versions but doesn't works. Has anyone tryed this?
These are the Hard and Software that I'm using:
* BOP 36-12M with BIT 400-B (Kepco)
* PCI 1670 GPIB Card (Advantech)
* PC P4 3 GHz; 2 Gb RAM
* Lab View 7 Express
Please, can you help me?
Thanks.
Jon García
EUP de San Sebastián (EHU / UPV)
(3,433 Views)
If you buy the card from advantech, it is not more than reasonable that they help you with the driver for that card.
greetings from the Netherlands
(3,428 Views)
You should contact Advantech technical support for that.
I will recommend you to use NI HW if you ar using NI SW.
Jaime Cabrera
NI Applications Engineering.
Jaime Cabrera
NI Applications Engineering Spain
(3,397 Views)
