Beep.vi
I am using LabVIEW 8.0 to do a project. Beep.vi is used in this project. I typed in Frequency as 100, Duration as 1000, uncheck the system alert, and saved all (including the project). But when I run it, the settings of beep went back default (system alert). Could anyone know how to make it change?
Qi Lin
(3,953 Views)
Hi Qi Lin,
where do you change the settings? I hope not in the beep.vi.
Mike
(3,951 Views)
I double clicked on the beep icon. And changed the values there.
Thanks.
(3,949 Views)
Thanks a lot. I got the answer.
Qi Lin
(3,945 Views)
