Bertan - Series 225 VISA issues
I am trying to use the Bertan 225 VISA driver. However, using the driver I cannot turn on the voltage (it does not produce any errors and the code it puts out seems to match the user manual).
Does anyone have any experience with this? Or any ideas?
(3,586 Views)
Some added information.
I can put the codes in
L00.500K
L1.0000M
OC1OE1OE2
SE1SC1
P0.05000K
And I can turn the instrument to local and it goes to 50 V (0.05 kV). Then I can put in
L00.500K
L1.0000M
OC1OE1OE2
SE1SC1
P0.10000K
And I can turn the instrument to local and it goes to 100 V (0.1 kV).
(3,549 Views)
Hi GBtSLK88,
How are you monitoring the output? Could you post the comparison of the code it puts out and how that matches the user manual?
-Letitsnow
(3,539 Views)
I figured it out. I thought that a switch was local one direction , remote in the other . But it was actually both.
(3,537 Views)
