Blue Screen of Death
After a day of successfully testing my program. I restarted my computer and the next time that I tried to run my program I received the blue screen of death. I am running LabVIEW 8.5 on 64-bit Windows 7. I have seen that the gpib-usb-b driver can give the blue screen of death, but that shouldn't be the case for me because according to the windows I am using version 3.1.0 which should be stable right? I also get a blue screen of death when I start NI-MAX. Any thoughts on what could be wrong? Thank you for your consideration!
(4,391 Views)
Hi buckyballer,
One of the possible causes for the blue screen would be the LabVIEW and DAQmx version compatibility with Windows 7. The earliest version of LabVIEW that is compatibile with Windows 7 is 2009SP1. You can see version compatiblity at this link here:
Windows Version Compatibility with LabVIEW: https://www.ni.com/en/support/documentation/compatibility/17/labview-and-microsoft-windows-compatibi...
I hope this helps,
Anna L
(4,333 Views)
Hi Anna,
Thank you for the reply. I will try to update DAQmx and I will let you know what happens! Thank you again for your help.
(4,272 Views)
