04-04-2006 09:20 AM
Chris,
I think I see the problem now. I added some code to display more information returned by VISA VIs. I was trying to get descriptive information for each of the resources I found, and apparently the Interface Description property provides incorrect results. I did load the NI-VISA 3.5 with latest MAX as you requested. Attached is the visaconf.ini file you requested, as well as some screen shots of the Max device list and the vi front panel and block diagram that I am using to process the VISA resource list. Let me know what you think.
04-04-2006 09:21 AM
04-04-2006 10:43 AM
04-04-2006 11:07 AM
