08-25-2006 09:24 PM
08-28-2006
02:14 PM
- last edited on
04-06-2026
04:59 PM
by
Content Cleaner
[broken link removed; article no longer available]
08-28-2006 02:45 PM
08-28-2006
02:54 PM
- last edited on
04-06-2026
05:00 PM
by
Content Cleaner
Hi JLS,
Thanks for replying! I think one of the quirks with this is the use of this "virtual serial port." How do I know if I need to use this? Also, how does one create a virtual serial port? It looks like maybe you need some kind of Windows software to do it. Then, there's apparently a Palm OS SDK 5 toolkit to download but I'm not sure if I need it or not for this. The KB is linked below. I was just wondering if it really was that complicated or not. I have had serious issues trying to download that SDK kit...the website is malfunctioning and tech support is pretty much nonexistent.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/15987c8cb752ead786256dc20070b433?OpenDocument
-Phil
08-29-2006
01:39 PM
- last edited on
04-06-2026
05:00 PM
by
Content Cleaner
I think you're referring to this part of the document you linked:
"The LabVIEW PDA module can also utilize Bluetooth support by taking advantage of the virtual serial driver most Bluetooth drivers provide. In general the driver supports only one active serial channel at a time, which can be either an outbound (client) port or an inbound (server) port. There are different methods to initialize the port between the PocketPC and Palm modules, however once the connection is made the current Serial PDA VIs are used."
The idea of a virtual serial port refers only to your PDA side, and that's if you have built-in bluetooth support on your PDA. Basically, some bluetooth devices will expose a "virtual serial port" as an interface to programming them. They usually have an alias like other serial ports, such as COM2, where you can then program that bluetooth "resource" as a serial port by writing your favorite string data.
On the Windows side, your serial-bluetooth converter should completely abstract away the details of the bluetooth interface. In that case, all you will see on your Windows machine is the usual serial port with its usual alias, say COM1. When you write data to that resource (just as you would any serial port, which for you will likely be using the NI-VISA API functions), it will be received by your converter (since it is physically connected to that physical port) and susequently broadcasted via bluetooth. Thus, there should be no concept of a virtual serial port when you use a serial-bluetooth converter, and thus you shouldn't have to worry about this on your Windows side.
Further, if you have a standard serial port on your PDA, and you are also using a serial-bluetooth converter there, you will again be abstracting away all details of bluetooth, and you'll simply be programming a serial port on your PDA side as well. Now, the available API for serial programming with LabVIEW PDA depends on your version of LabVIEW PDA. Starting with version 8.2, NI-VISA is supported with LabVIEW PDA, so it'll be just like programming your Windows side serial ports. For versions previous to 8.2, you'll have to use the "Serial Compatibility VIs" - Don't be confused by the fact that those actually have VISA functions underneath. LabVIEW PDA actually replaces those functions entirely with appropriate functions for the PDA before your program is downloaded to your PDA target - this is a common point of confusion for those who dig deeper and find VISA under the serial compatibility API.
Does that clear up your confusion? I hope so, and tried to include some other information to prevent any confusion about other related details.
Best Regards,
JLS
08-29-2006 09:22 PM
JLS,
Success!!! Yes your explanation above was really good. I was able to use that KB with the example VIs, LLB, and .c file to make a virtual serial port on the PDA and exchange data to/from my PC. Cool!
Here's the next quirk. I wrote a similar app that basically just continuously sends data (every 500 msec) from the PC to the PDA. The PDA graphs it (every 500 msec). Sometimes it's obvious they're not in sync...the PDA will plot a very big or very small number when it shouldn't. I know all the serial settings match EXCEPT for flow control. I noticed on that "BT Serial Port Init" subVI there is no input argument for flow control type. So what kind is it? I know that my serial-to-bluetooth adapter on my PC can only be set for RTS/CTS, there are no other choices. Might this be the cause of the errant data transfer? Or could it be something else?
Thanks, Phil
08-30-2006 03:04 PM - edited 08-30-2006 03:04 PM
RTS/CTS is commonly referred to as hardware flow control, because the RTS and CTS lines of the standard RS-232 DB9 interface are basically used to let the other side know "hey, my buffer is filling up, hold on a minute" and then later to say "ok, my buffer is empty enough for you to send data again." Well, since there isn't a hard connection between your PDA and your PC. Since there are no wires in your PDA-PC connection, I suspect the following is happening, and is the reason for your adapter requiring RTS/CTS control:
Suppose your PDA's bluetooth buffer gets, say, 75% full, and that there is a flow control message mechanism built into bluetooth to tell the other side to wait (I am speculating here - I don't know this specifically exists for bluetooth). Then we would expect your PDA to send that message, which would be received by your bluetooth adapter on your PC. This message could be translated and then used to set the RTS/CTS lines so that your PC (underneath really the serial port) would "wait" (stop sending data) until it received a message from the PDA saying it was ok to begin sending again. At this point the adapter would again set the RTS/CTS lines to tell the serial port that it was ok to start sending data again (which of course your adapter receives and broadcasts via bluetooth).
Thus, this may be the cause for the errant data, but I think I would have a better idea of whether or not this is the case if I could see the data - can you attach a screenshot of a). "good" data and b). "bad" data, so that I can compare them. And keep in mind that, if you're using a bluetooth interface which is built into your PDA, the concept of RTS/CTS control for that resource doesn't really make sense - that is an RS-232 specific concept, not bluetooth, and the "virtual serial port" isn't actually a serial port... there's no RS-232 interface... no wires 🙂
Ok, I hope this gets us a step closer...
Best Regards,
JLS
Message Edited by JLS on 08-30-2006 03:05 PM
08-30-2006 03:48 PM
JLS,
I think it's faster just to describe in writing "good" and "bad" data. I'm not sure how to take screenshots of a PDA. I write a number (random I32 from 0-100) from my laptop (with serial adapter) to PDA every 500 msec. At the PDA end I am then reading that number also every 500 msec. Let's say I was constantly writing the number 50. You could see on the PDA sometimes it will read 50 but sometimes it will read 505 or 5050 or 5 or 0. It's pretty easy to see it's some kind of flow control or handshaking issue. Depending on the timing, there may be cases where the PDA reads the value from the PC, then tries to read again but there's nothing there, so it reads 0. Or there may be a case where two serial 'write' commands get sent before a read ever occurs, so you get data like '5050'. My question is without the proper flow control how do you adjust for this? Also should the serial flow control setting on my laptop LV program and the bluetooth adapter be set to RTS/CTS or should the LV program be set to none? (Remember the adapter can ONLY be set to RTS CTS).
Phil
08-30-2006 08:18 PM
JLS,
I had another thought. You mentioned above that with Labview 8.20, VISA is supported in the PDA module. So would you suspect that this issue could resolve itself if I had this added level of control? In that case maybe I'll just wait for my 8.20 to ship. ![]()
-PR
08-31-2006 01:57 PM
