Bronkhorst driver for LabView 8.0
Dear all,
For my job, I have to built up a new machine. I will have to measure the gasflow, and at a critical flow, open a valve. In the side, I will measure a differance of pressure and a weight. As my background is far away of programming, it will be a great challenge 🙂
Regarding the flow, I have a Bronkhorst flowmeter, with a FlowDDE interface. Hence, I guess this VI could help me a lot : http://www.morechemistry.com/labview/driver-bronkhorst/vi_bronkhorst_01.html
The problem is when I open this VI, it state that I need at least LabView 8.2. I have the 8.0.
Does it exist a way to use this VI anyway? Or did I miss a other usable VI to import easely data from FlowDDE? ( I have got the FlowDDE 4.62)
Thank you.
Best regards
Renisaac
(5,712 Views)
Accepted by topic author Renisaac
Attached is the VI in 8.0.
DDE. Interesting.
If you run into this again you can post downconvert requests in the Downconvert VI Requests thread.
(5,698 Views)
Thank you very much, smercurio_fc .
I can open and use this VI... I only have to discover how does it work.
Good to know, this downconvert.
Best regards.
Renisaac
(5,681 Views)
