Build my own interface to NAT9914 on aa ADSP2191 based system (analog devices)
I have to build software drivers and interfaces to for a board that based an ADSP2191 ( Analog devices) with a NAT9914 as Gpib interface .
I have also a SRAM where the NAT9914 registers are mapped .
I should build only asimple software who is able to read and write to the GPIB .
Do you have ane programming example or any other information that would help my job?
Thank's ,
Massimo Rofi
(3,360 Views)
Woooow....
I have to do something like you ! if you don't have anything mind I can work
with you on this !
Gorgo
(3,360 Views)
Hi GorGo,
I will be happy to exchange with you my experiences .
If you want wi can get in touch with email.
My email is m.rofi@sielte.it .
Bye,
Massimo
(3,360 Views)
You will find the following links helpful, http://www.ni.com/support/gpib/reg_prog.htm and the links based on a search for "NAT9914" at http://search.ni.com/?col=alldocs&layout=TechResources&ql=a
(3,360 Views)
