09-14-2009 04:19 AM - edited 09-14-2009 04:19 AM
Solved! Go to Solution.
09-14-2009 07:02 AM
Why you want that? Post in detail so that there maybe a workaround.
Note: Use the composer box to type your query in a detailed manner rather than using the subject line.
09-14-2009 12:09 PM
The default is modern controls and I change it always to classic.
I'm classic and the classic controls are far more easy to adapt to what I want.
goto options and look along all tabs to find the place where new vi's can be set to modern controls by default
But keep in mind only new i's, old vi's have to be changed in the properties of that vi.
goodluck
09-15-2009 04:10 AM
Greetings!
Thanks for the suggestion Albert!..it works.. classic is classic!..I am a recent graduate & new to Labview, so felt like using the Modern controls.
09-16-2009 12:06 PM
09-18-2009 03:54 AM
Sure! I will try my best!
