C++ Help with GPIB and 488.1 device
To Any and All,
Can you tell me what I am doing wrong here?
#include
<iostream>
#include
<windows.h>
#include
"ni488.h"
int main()
int gpib;
gpib = ibfindA(
"GPIB0");
ibsic(gpib);
ibcmd(gpib,
"_?@3",4L);
ibwrt(gpib,
"C2",2L);
ibcmd(gpib,
"_",1L);
ibcmd(gpib,
"_?@3",4L);
ibwrt(gpib,
"A0",2L);
ibcmd(gpib,
"_",1L);
return 0;
The device does not respond to myt commands. I think it is probably with my board initialization, but I am at a loss. I know the commands work with ibic.exe, in the order presented and the hardware and unit are working. So it must be my coding.
If I use ibfind I get this error;
error C2664: 'ibfindW' : cannot convert parameter 1 from 'const char [6]' to 'LPCWSTR'
1> Types pointed to are unrelated; conversion requires reinterpret_cast, C-style cast or function-style cast
Message 1 of 11
(6,809 Views)
what is the returned status
status1=ibsic(gpib);
status2=ibcmd(gpib,"_?@3",4L);
status3=ibwrt(gpib,"C2",2L);
Hint: You can check the returned status variables (if not 0) with the GPIB error coding list. If the stuff works fine, status should be 0.
Best regards peter
Message 2 of 11
(6,801 Views)
You should use ibfind() but if you are going to use ibfinda() then you need to pass a value of type LPCSTR, therefore you need to cast "GPIB0".
also you should also capture the return values so you can handle the error conditions
Regards
Ray Farmer
Regards
Ray Farmer
Message 3 of 11
(6,796 Views)
muellerp,
I just got in this morning, but give me a little bit and I can get you the return values. I will either attach the NI Spy or re-write my code to capture the values.
Message Edited by shard923 on 01-16-2008 07:48 AM
Message 4 of 11
(6,784 Views)
Ray Farmer,
What the heck is that LPCSTR and how do I cast to it. Do I just do a <static_cast>LPCSTR ? Is that some sort of Microsoft data type? Thank you for your help.
Message 5 of 11
(6,782 Views)
You can declare a variable ie
LPCSTR device = "GPIB0";
gpib= ibfind(device);
or
gpib = ibfind ((LPCSTR)"GPIB0");
regards
Ray Farmer
Regards
Ray Farmer
Message 6 of 11
(6,779 Views)
Ray,
When I use
gpib = ibfind(LPCWSTR(
"GPIB0"));
the project will compile but then NI Spy tells me that iberr is EVDR, or "Error connecting to driver or device" and then all the following commands then fail.
Message 7 of 11
(6,773 Views)
muellerp,
I looked at the script with NI Spy and it told me all commands went through okay except my ibwrt. A coworker here had changed the PAD of the GPIB0 to 25 instead of 0, so the ibwrt wasn't working. Thank you for your help. I also found that despite what the manual and programming instructions say for the units I am working with, the "B" model and the "C" model are different in how they react to IEEE commands.
Message 8 of 11
(6,772 Views)
To shard923:
I'm quite interested in the work you are doing on ADT-222B. Would you please contact me directly - that_mail@yahoo.com
Thank you,
Message 9 of 11
(6,640 Views)
Ray,
I ended up fixing this by using a multi-byte character set in the properties drop-down of the project menu. After that, ta-da, no complaints from the compiler.
Message 10 of 11
(6,540 Views)
