I'm using the VISA Driver to run a C# program with the USB GPIB adapter.
The C# program is used on several PCs every year, from different users. Also other LabVIEW installations are sometimes running on that PCs.
We are often facing the problem with the correct driver version. If not the correct version is installed, the software is not running.
Is there a way to create C# program for different VISA versions?
Or can I create a small installer with this driver version to run with the C# program.
Thanks for you help.
