CAMTEC power supply with USB interface
Has anyone already controlled a CAMTEC power supply with an USB2.0 UI.Drive-Interface by LabVIEW ?
Many thanks in advance for any advice.
(5,063 Views)
Looks like you'll need to call a .NET DLL unless they wrote some wrapper LabVIEW VIs .
(5,055 Views)
Accepted by topic author JB
You can use the "CAMTEC Netzteilansteuerung USB2.0 UI.Drive-Interface" which provides a .NET library for LabVIEW. It can be downloaded here.
I have rewritten it because it doesn't satisfy good programming style.
(4,891 Views)
