CAN bus using interface Labview and pic18f
hello 🙂
i want to use CAN BUS WITH PIC18F4550  for communicate with others devices using protocol CAN , i  i want to use interface labview,
so it is possible to use NI-CAN labview with microcontrollers ? and how ?
thank youu
Spoiler
(4,635 Views)
if the pic has software to act as a slave it should work.
greetings from the Netherlands
(4,627 Views)
thank you for your replied man 🙂
(4,533 Views)
