CG635 (2.05 GHz synthesized clock generator) Labview driver needed
Dear NI Discussion Forum,   Is there a SRS CG635 (2.05 GHz synthesized clock generator)Labview driver available that I can download?  I would like to check for driver availability before investing too much time on controlling this SRS CG635 clock generator unit.   Many thanks.   MYMYMY
(4,072 Views)
If you don't find it at http://www.ni.com/idnet/, try the manufacturer. Otherwise, you will need to write your own.
(4,055 Views)
Dear nyc,
I did check both http://www.ni.com/idnet/ & SRS (the manufacturer).  SRS said that they dsisn't have this driver available.
MYTY
(4,047 Views)
Hi MYTY,
Have you created any driver for the CG635? Is it shareable?
Priyadarsini S
(3,887 Views)
