COM adapter not working
i created a c++ program using the IviDMM classdriverfunctions.
The program is working fine with a PXI NI DMM (IVI-C).
Now i tried to exchange it with an Agilent 34980A DMM (IVI-COM).
But now i get error -1074118124 = "Unknown status code" or -1074118653 = Unknown status code.
What can i try to make this running?
Thx for all tips
best regards
My setup is:
Windows 7 64bit
IVI Compliance package 16.0.1 (with checked COM-adapter option during install)
NI MAX 16.0.0.f0
NI-DMM
Ag34980 ivi driver 1_5_5_0
(3,316 Views)
this appears to be an issue with the Agilent IVI-COM Driver. There have been report of these errors when using the Agilent 34980A via GPIB interface.
http://forums.ni.com/ni/board/crawl_message?board.id=320&message.id=2018
http://forums.ni.com/t5/Switch-Hardware-and-Software/Agilent-34980-17500-Error/m-p/538180
http://forums.ni.com/t5/Switch-Hardware-and-Software/Error-1074118124/td-p/1411578
Could you change plug in the device via USB and test again?
Best regards
Andreas Gareis
Senior Applications Engineer, NI
Certified LabVIEW Developer & TestStand Architect
(3,268 Views)
The instrument is connected with LAN.
(3,266 Views)
