COMMUNICATE WITH SORENSON POWER SUPPLY XPF 60-20DP
I try to look for the USB driver for Sorenson XPF 60 - 20DP power supply.  I am using labview 2011.
Please guide me how to communicate with this power supply using USB and GPIB port.
Thank you,
(4,913 Views)
Hi Trex600N,
I took a quick look through the drivers available on ni.com/idnet, and it looks like there are several sets of drivers available for Sorenson Power Supplies: http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/ssnav:idr/q/sorenson%20power.... I didn’t see the XPF line listed, but it’s possible that one of the other lines is similar enough that the same drivers will work for your device. You can always ask Sorenson if they have a suggestion on which drivers you should use.
If they don’t have drivers published for your device, you can always use VISA calls to create your own drivers. Here’s a tutorial that describes this process: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YFtOCAW&l=en-US.
Kathryn K.
Technical Support Engineer
http://ni.com/support
(4,858 Views)
