CP210x UART bridge in TH1941 multimeter
I'm trying to connect my digital multimeter with labview 2016, i downloaded the driver for the UART bridge in silicon labs website and all is working OK, in the MAX, VISA test panel  > Input/Output i send the IDN command and its working its sends the model and version of the multimeter.
So, i need to connect the multimeter with labview, for collect data and start working on my experiment. What i need to do for start capting data from multimeter? I need to do instrument driver? or i need to do a program in labview to read serial port??
The multimeter es Chinese and in labview i cant find the driver of my multimeter.
The multimeter is a TH1942 USB with cp210x USB UART bridge for pc connection.
Thank you for help!!!
(4,294 Views)
If there are no driver library, then pull out the manual and figure out which commands you need.  It will show up as a serial port, so you can just use VISA to write to and read from the DMM.
(4,281 Views)
Thank you for your answer, but how i can read the data with VISA Test Panel???
Only i can write commands (TH1941 manual) to change between ohms and volts and this kind of commands.
But how can i receive the data from the multimeter?
In the manual, they purpose a comunication program example in C language, but i need to use it in labview, how i can do it?
(4,265 Views)
Have you looked in the palettes at all?  There is a whole palette just for VISA communications (Instrument I/O->VISA).
(4,261 Views)
Hi crossruiz,
I done the comunication and write data in txt file, adding some subVis. But I think the read or the write is too slow. Now is capting 5-6 values in one second. But my multimeter transfers at 25Hz, 25 values in one second, how i can sinchronize it for get a real reading?
Thanks for helping!!
(4,224 Views)
